restrictor plates
Old 02-27-2002, 12:37 PM
ehn84
Cruising
ehn84's Avatar
Default restrictor plates
Does anyone know how to go about removing the restrictor plates on an 84? :confused:
Old 02-27-2002, 01:31 PM
CFI-EFI
CFI-EFI's Avatar
Default Re: restrictor plates (ehn84)
You gotta have 'em for Daytona and Talledega.
Old 02-27-2002, 06:47 PM
BBA
BBA's Avatar
Remove the throttle bodies, remove the upper plenum cover and cut them off.
Old 02-27-2002, 11:53 PM
blk90rdstr
blk90rdstr's Avatar
Default Re: restrictor plates (BBA)
There just swirl plates not really restrictor plates. I dont know how substantial the gain is for removing them but it wont do much for the idle. Try over in the crossfire injection vault. I was gonna cut mine out but someone there talked me out of it. They do have an excellent step by step instruction for that mod and many more. :cheers:
Old 02-28-2002, 08:16 AM
merrick
merrick's Avatar
Default Re: restrictor plates (CFI-EFI)
:lol:
Old 02-28-2002, 05:29 PM
1996man
1996man's Avatar
at the risk of sounding dumb, what exactly is a restrictor plate and what does it do?
i know it makes the car slower on nascar but i dont know much other than that
Old 02-28-2002, 06:45 PM
BBA
BBA's Avatar
Default Re: restrictor plates (1996man)
On the CFI manifold, it is a little vaned plate that sits directly under the throttle body's blades. It is part of the upper manifold plenum and GM refers to this one in particular as a "diffuser". Removing it reduces airflow obstructions, so people refer to it as a "restrictor".
In nascar, a restrictor plate is a metal plate with 4 calibrated holes that sit under the carb's throttle blades, with the purpose of limiting intake system air flow to something like 390 CFM. ( and they still make 700+ HP ).
Old 02-28-2002, 09:26 PM
JOHNL
JOHNL's Avatar
Heres the Crossfire Forum Go to the tech section at the top of the page. http://www.crossfire.homeip.net:81/c...artdefault.asp
To restrictor plates
Quick Reply: restrictor plates
