J55 brake pic please
Old 09-10-2010, 08:34 PM
mcm95403
Support Corvetteforum!
mcm95403's Avatar
Default J55 brake pic please
Hi Guys,
I just got my J55 calipers, abutment brackets and DRM adapters for the 84 and I'm a little lost. I don't see what "attaches" the calipers to anything. Can someone post or e-mail me pics of what J55 brakes look like when assembled please?
Old 09-10-2010, 09:50 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
The biggest difference with the J55 is how they mount to the abutment bracket.
Make sure you load the calipers so the brake pad end with the notch is down.
Be sure the spring clips on the pad are ALL the way in the caliper, if not you will have a problem fitting them over the disk.
The closed end of the pad goes under the abutment bracket at the top.
At the bottom you slide a pin from front to back (or back to front) and secure it with an e clip.
If I get some time I'll post some pictures.
Old 09-10-2010, 09:52 PM
mcm95403
mcm95403's Avatar
Thanks! I was able to find a good side-shot and your explanation fills in the blanks. I had a feeling that was how they go together, but I don't have a set of pads yet to mock it all up.
It seems kind of spooky that an interference fit is basically all that keeps them together, but it obviously works.
Old 09-10-2010, 09:55 PM
vetteoz
vetteoz's Avatar
The through pin holds everything together
I recall past posts stating you may have to clearance the original mounting tabs on the early spindles for the DRM adapters to fit correctly
Old 09-10-2010, 10:49 PM
Churchkey
Churchkey's Avatar
Old 09-10-2010, 10:53 PM
mcm95403
mcm95403's Avatar
Thanks for the info, I'll make sure to test fit them well before I do the swap.
Old 09-11-2010, 01:39 PM
batchman
batchman's Avatar
I find it preferable to place the pin with the C-clip facing out. That way I can give it a visual check at tire changeover and if it works its' way out (happened to us a couple times) it won't hit a wheel spoke.
Cheers,
- Jeff
Old 09-18-2010, 09:50 PM
ben73
ben73's Avatar
Will these fit under 16" wheels, or do you need 17's?
Thanks.
Old 09-18-2010, 09:56 PM
ben73
ben73's Avatar
Thanks.
Old 09-19-2010, 12:34 AM
1985 Corvette
1985 Corvette's Avatar
17s if you want the J55 option.
Old 09-19-2010, 01:21 AM
mcm95403
mcm95403's Avatar
I saw several posts by people claiming these fit with the 16" wheels - do you know for sure that's wrong?
Old 09-19-2010, 03:03 AM
rodj
rodj's Avatar
Clear stock Enkei made 16" wheels fine
Old 09-19-2010, 08:53 AM
Rob31
Rob31's Avatar
Not in the front they wont .
Just checked mine . They dont say enki anywhere . and the were 16/8.5 inch wheels
So "rodj may be correct .
Old 09-19-2010, 10:13 AM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
You need 17" wheels to clear the J55 (13"rotors).
Old 09-19-2010, 04:58 PM
rodj
rodj's Avatar
I have J55's on my '87 and they clear the factory 16 X 9.5" Enkei made wheels fine.
Has been well documented here in the past, the other factory wheels ( General ??? ) are a thicker rim section and won't clear
Old 09-19-2010, 07:28 PM
PLRX
PLRX's Avatar
2017 C4 of Year
Are the Generals the 16"x8.5"?
Old 09-23-2010, 01:13 AM
aceesquire
aceesquire's Avatar
do i need an adapter plate to mount the J55 calipers on my 86? if so, where do i get it? i just bought a set of grand sport calipers. they came with the mounting bracket and the 13" rotors but i'm not sure, how to install these. i've been searching for solid answers for a few hours. this thread has got the closest to an answer, but i'm still not sure
To J55 brake pic please
Old 09-23-2010, 01:41 AM
mcm95403
mcm95403's Avatar
In my case I'm using discontinued DRM (Doug Rippie Motorsports) adapters. Since they're discontinued, I'm considering having them duplicated.
Old 09-23-2010, 05:07 AM
rodj
rodj's Avatar
Yes
PM sent
Old 09-23-2010, 09:39 AM
Rob31
Rob31's Avatar
I tookmine off an 84 with the factory bracket . I had to use a washer from my single piston caliper for clearance on the rotor. Still had to grind a good .040off the bracket near the rotor.
I have a 86
Quick Reply: J55 brake pic please
