How easy to change front pump of 700r4/4l60?
hey guys,buddy of mine helped me do a converter and knocked out the front pump instead,just my luck.How easy are they to change,any tips or tricks,and its out of a 1992 vette,so is it a 700r4 or a 4ldo that i have and any way to tell?
thanks mike
thanks mike
The internals are the same for both of these trannys, with the exception of the solenoids in the 4L60E and the TV cable on the 700R4. The pump is the same. Take a look at Mad dog transmissions.
www.maddogtransmissions.com
It's not a hard job but it is tedious. IIRC the bolts holding the pump in are 1/4" but in any case, whatever size they are get a couple 3-4" bolts the same size and cut the hex heads off. Take all the bolts out and replace two of them opposite each other with the cut off bolts, these will help re-install the pump. Be real careful when pulling the pump out so the clutch drum right behind it doesn't come with it. You can LIGHTLY pry the pump up a bit to get it started. Take the old pump & lay it aside. Get a new rubber ring that goes around the pump and put it on the replacement pump. Use vaseline to grease the perimeter of the pump so it will slide back in place. Tap lightly with a rubber or plastic hammer to seat the pump then remove the cutoff bolts & re-install the pump bolts then torque to specs. If you need a pump I have one out of a 700R4 in good shape but I don't know if it will work in your trans. If it will and you are interested pm me. When you re-install the converter be sure there is about 1/2" clearance between the converter & the flexplate before tightening any bolts. You may need to turn & wiggle the converter to get it all the way in but this step is critical as you already know.
1992 is a 700 R4 trans.
Early 700 R4's had a 7 vane pump rotor.
After 1984, 1985 & up 700R4's had a 10 vane pump rotor.
4L60E transmissions had a 13 vane pump rotor.
You need the mid year 1987-1992 front pump assembly for you 1992 trans.
Its specially built for the Auxillary Valvebody equipped 700R4 trans that your 1992 C4 Vette has.
Brian
The Main Boost Valve and Reverse Boost Valve size in .000 inches is unique to all stock C4 transmissions.
Transfer your old boost valves if unsure.
Don't install them backwards or your trans will have low line pressure.
And fail shortly afterwards.
Check the Converter Valve also in the replacement front pump.
Any wear or scoring, not good.
Check both pump halves closely.
Must be flat and distortion free.
Must shine like a mirror all machined surfaces.
If not, pass on that front pump and keep searching till you get one in 100% perfect condition.
Brian
Its best outlined in the Blue and Green ATSG transmission Books.
You have to Read and Re-Read carefully each page in those books to understand all changes GM Hyrdramatic engineers made throughout the years.
It is very confusing at times to many home and professional mechanics.
Brian
There are so many different changes and improvements they made on these 700R4 transmissions with each succeeding model year.
Brian
Brian
I have alot of experience and knowledge like you do thats all.
Comes with years being a mechanic and working in GM dealerships.
Wrenching on racecars at night.
I'm no different from you.
I'm booksmart. Helped me ace all and every ASE test I have ever taken.
You have at least another 10 years of turning wrenches longer than I have.
That means much...............experience and lessons learned for lifetime.
Thousands of them.
Its important to share some of our knowledge with others here.
Keeping all the knowledge to ourselves doesn't do anybody much good.
Brian
Thousands of them.
Brian
wow,thanks alot guys,im def gonna get a new front pump,dont wanna take a chance on a used one.thanks for all the tips and tricks also.so i have to reuse the rubber oring?the new pump wonnt have any on it?
thanks mike
thanks mike
Or there are several companies offering remanufactured 700R4 front pumps.
There may be a NOS GM front pump assembly for your Vette somewhere,
But it would take some searching for it.
I checked last summer at my local GM dealership for the 1987-1/2 to 1992 700R4 pump assembly.
It was discontinued.
You will need to buy the large front pump O-ring and the matching paper gasket that sits in the recess of the trans case.
Brian
yeah it can be a reman not worried if its gm or not,ok thanks for that info i guess where ever i get the pump from shld have the gasket and the seal also
There are dozens of specialty transmissions shops to choose from.
Internet included.
I recommend Dana @ Probuilt Transmissions in California.
He is honest, very helpful, and Tech Savy like me.
Or contact Pete K. here on C4.
He is good guy, a Crafstman putting together anything, and honest too.
I have 1 spare 87-1/2 to 1992 700R4 front pump in good used condition.
Keeping it for another 700R4 trans I may put together this year for my 63 Pontiac GP.
Better fuel economy instead of the Turbo 400 trans in it now.
Brian
Great Stand Up Guy.
A Gentleman every time he got me to me here on C4 with trans tech questions much of last year 2010.
Brian
Mike,
I dont log on here much these days, but feel free to call or e-mail.
Anything I have that can help (good used stuff) you are welcome to. That includes free labor, if you want to take a ride up to Wilkes-Barre.
I would only ask you pay for my out of pocket.
I always take care of the guys that have taken care of me.
PK
PK
Need help on a transmission?
Remember the transmission is only as good as the builder, even if you are using all top of the line components. There is a lot more than just exchanging parts when remanufacturing a transmission. I have been rebuilding high performance, racing and daily driver transmissions for over 26 years and I am a man with integrity. One thing for sure, you will not be disappointed. We are always available to provide technical assistance to help ensure that we setup the right transmission and torque converter for your application.
We build bulletproof transmissions! It is critical that we know how you are running your vehicle and the needs you have for your application. If you're running nitrous, superchargers or turbo-chargers, please be sure to give us this information. We cannot setup the right transmission for your application without this information.
Please contact me for a professional consultation regarding your needs. We are happy to provide you with references both here in the United States and Internationally. Be sure to check out our website at maddogtransmissions.com
Hear what our customers and fans say on our Facebook Page at www.facebook.com/maddogtransmissions
We also accept orders over the phone. Be sure to contact us and we will recommend the correct transmission for your application. For your convenience, we accept PayPal and all major credit and debit cards.
If you prefer, we can call you personally, just e-mail us your phone number.
All our transmissions are very strong and reliable, and can be used for everyday driving. Extended warranties are also available.
Thank You,
"Mad Dog" Lou
Mad Dog Transmissions
Phone 770-781-0949
Fax 770-781-0969
Web: www.maddogtransmissions.com
Facebook: www.facebook.com/maddogtransmissions
Twitter: www.twitter.com/maddoglou
YouTube: www.youtube.com/maddogtransmissions
Thank You,
"Mad Dog" Lou
Phone 770-781-0949
Fax 770-781-0969
first thing remove pan then the lockup soleniod and reverse tube then unbolt the 13mm bolts i use a flat chissile between the pump and the drum it will come up with out much force it would be wise to dissassemble the rest of the tranny and inspect it why you ask the metal shavings can get in to the valve body sticking the tv valve and youll probley find worn 3-4 clutches most of the time the pump can be rebuilt if the body isnt damaged you should replace the rotor with a 4l60e 13vane and a sonnax boost valve its a 2 piece assembly on 700s u need both oringed with a .500 boost valve
