Black oil from a/c compressor
Old 04-19-2002, 11:15 AM
Bluevette85
Bluevette85's Avatar
Default Black oil from a/c compressor
When the a/c is running, a black oil is sprayed on the underside of the hood from the compressor. Is this coming from the clutch or the compressor and can it be fixed without buying a new compressor?
Old 04-19-2002, 01:53 PM
JonM
JonM's Avatar
Default Re: Black oil from a/c compressor (Bluevette85)
It can be fixed but a remanufactured compressor is just as expensive as fixing it. Make sure you clean off that oil from your hood ASAP...it can impregnate the fiberglass and make the paint above bubble.
Old 04-19-2002, 02:27 PM
weekendwrench
weekendwrench's Avatar
It is most likely due to the shaft seal leaking. I would also suggest that you repalce the entire compressor. If you are going to switch the r134a you should change the orrifice tube and evaporator. Here are a couple useful links.
http://www.aircondition.com/
http://www.ackits.com/
Old 04-19-2002, 09:03 PM
Bluevette85
I have already switched to r134. I've seen metal shrouds that can be mounted to the compressor to stop the oil from splattering. I might fabricate something and see how much life the compressor has left.
To Black oil from a/c compressor
Quick Reply: Black oil from a/c compressor
