Gas in oil pan again!!!
Old 07-12-2011, 09:36 PM
Ricky 91 vette
Ricky 91 vette's Avatar
Default Gas in oil pan again!!!
Hi everyone, like couple weeks ago I had all the sudden white cloud of smoke coming out of the exsaust, rich reading on the wide band, loose in power, it turned to be the oil pan filled with gas and the FPR difrom broken, I replaced it from Autozone, changed the oil and filter twice, and everything seemed to be ok, after like a week of that, I run out of gas in the freeway exit 200 feet away from the gas station I was trying to get to lol, filled it up with gas, drove it again normally for like 20 miles, suddenly it died on me in the free way, pulled over, tried to start it couple times, it cranked really fast but no start , waited like 3 min, tried again and it started bu felt like the engine was chocked with fuel, hit the gas pedal couple times and it seemed to be running normally now, drove it back home, checked the oil next day and it was fine, drove it around for like 4 or 5 days, and the dar was starting normally and running normally, yesterday driving At 75 mil/h it died on me the same way it did before, this time never wanted to start again, I was desperate from being late to work, kept hitting the starter for like 15 min till the battery died, got it towed home, charged the battery, and went to work LATE!
Today tried to start it again, the engine was very heavy on the starter,checked the dip stick and was gas !!! I emptied the oil and was full with gas, at least one gallon!! It was even leaking from the oil pan gasket from the front!!! Checked the FPR, and no gas on the vacuum hose, checked the fuel pressure, when I turn on the egnition, it shows 47 and then it drops fast to 30 in like 2 min!!!
Old 07-12-2011, 09:52 PM
Ricky 91 vette
Sorry guys for the long post, my question is: since the FPR is fine, where the gas got from into the oil pan? I think nothing left but injectors right? By the way fuel pump is one year old and the filter like 8 months, I only put 91 octane in it,,,
Old 07-12-2011, 10:12 PM
mikebassman
mikebassman's Avatar
Sounds like leaky injector . Take spark plugs out ?
Old 07-12-2011, 10:30 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
The only way fuel can get into the crankase if the regulator is alright is the injectors. Swap them out before your motor blows up.
Old 07-12-2011, 10:35 PM
Ricky 91 vette
If dirt got to the injectors from the empty tank, could it leave the ejector open? Its just really weird the way it died after pulling normally!! I will pull out the spark plugs
Old 07-12-2011, 10:40 PM
Midnight 85
Midnight 85's Avatar
Finalist 2020 C4 of the Year - Modified
Time to call Jon at FIC. His injectors will put the car back on the road again and probably with considerable more power.
AGENT 86
AGENT 86's Avatar
If your injectors are stock Multecs, they are prone to failure.
Do you have a fuel pressure tester ?
Old 07-12-2011, 10:44 PM
Ricky 91 vette
Originally Posted by 383vett
The only way fuel can get into the crankase if the regulator is all right is the injectors. Swap them out before your motor blows up.
The regulator is 1 week old and it's not leaking from the vacuum hose, my motor got mouth washed twice within a week!! I will be damn lucky if it will survive it!!
Old 07-12-2011, 11:08 PM
Ricky 91 vette
I did call him today, left him a message but not to buy a new ones!! These ones I have are buschIII !!! I bought them from John last year!!!
Old 07-13-2011, 09:44 AM
Midnight 85
Jon will make it right, but while you are waiting for him to respond check your fuel return line & be sure it isn't plugged up somehow.
Old 07-13-2011, 10:56 AM
383vett
383vett's Avatar
If those injectors are leaking, they are indeed bush.
Old 07-13-2011, 03:49 PM
Ricky 91 vette
I just talked to John now, and he was very understanding and told me to send them back to him to check them out, once I take it apart I will check the return line too
Old 07-13-2011, 11:08 PM
Ricky 91 vette
By the way, John asked me if I checked the Evaporator Purge Cannister too, I pulled the hose from the selinioed, and it was kind of clogged with carbon, so how to clean the system and is it possible to be a reason for the situation I have now?
Old 07-14-2011, 05:48 AM
Ricky 91 vette
i remember once i read a thread about cleaning it, but i cant find it and i dont remember the proceder!!
Old 07-14-2011, 08:33 AM
Midnight 85
Try the search then.
Old 07-14-2011, 01:11 PM
Snipescastle2
Snipescastle2's Avatar
I had a friend that his car (a mustang) had a bad computer that was shorting one of the Injectors all the time, it was like a solid stream of fuel going into his engine! his tank emptied very quickly, just as you described. either your injector/s is stuck, the ecm is shorting the injector/s ? I'd pull the plugs and see what you have as stated earlier.
Good luck!
Ben
Old 07-15-2011, 12:03 AM
Ricky 91 vette
Good luck!
Ben
waw!!! thats is scary!! i hope its not that, because that could mean also wiring shortage!!!
To Gas in oil pan again!!!
Ricky 91 vette
i did, still cant find it
Old 07-15-2011, 12:50 AM
Midnight 85
That figures, sorry, I've never had to do anything to my canister.
Old 07-15-2011, 05:08 AM
Ricky 91 vette
It's ok buddy, I knew you would help me if you would know, thanks
Quick Reply: Gas in oil pan again!!!
