1986 Dash Ilumination Problem
OK, here's what I have going on. When the headlight pull switch is switched off I have all dash illumination on: Stereo, HVAC, etc... When I turn the lights on all the exterior lights function normally, but I lose the dash illumination completely. Do I have a bad switch, or do I need to dig deeper? Let me know what you guys think.
You can twist that **** to control the brightness of the dash. If that doesn't solve the problem you most likely have a bad ground. Is it only the digital display or all the lights in the dash that don't illuminate?
