bast way to check vacuum leak
Old 04-03-2012, 11:58 AM
hitmanpty
hitmanpty's Avatar
Default bast way to check vacuum leak
what is the best way to check for vacuum leak????????
Old 04-03-2012, 06:24 PM
nickpe
nickpe's Avatar
starting fluid. spray a small amount at places like intake gasket, vacume hoses. if there is a leak it will change your idle speed
Old 04-03-2012, 08:50 PM
hitmanpty
hitmanpty's Avatar
how about smoke. I saw a youtube video where the guy use an cigar to blow smoke on the system. and you can see smoke coming out. makinig very easy to spot the leak
Old 04-03-2012, 10:05 PM
gunnerjuju
gunnerjuju's Avatar
I saw that video also but couldn't figure out where to blow
Old 04-03-2012, 10:12 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
That works great.
Jailor (01-08-2022)
Old 04-03-2012, 10:22 PM
WW7
WW7's Avatar
Man, you must really trust us posting something like this.....WW
Old 04-04-2012, 08:27 AM
Keystring
Keystring's Avatar
Brake booster hose.
Disconnect it from the booster, light up and 'blow'!!
Old 04-04-2012, 09:28 AM
hitmanpty
hitmanpty's Avatar
hey no shame. I dont know where to blow ether. I just dont want to be the one who say it
Old 04-04-2012, 11:02 AM
Midnight 85
Midnight 85's Avatar
Finalist 2020 C4 of the Year - Modified
I used the cigar smoke system once, I don't smoke, got sick as a dog and dizzy as hell and still didn't see any smoke escaping other than places I forgot to seal shut. You will need to seal the throttle body inlet. I've always had good luck with a water bottle, spray the water along the intake/head area and all the other intake areas that has a gasket. If the engine stumbles it means water is getting into the combustion chamber and you've found your leak. I've tried propane too but never had results.
Old 04-04-2012, 11:03 AM
Midnight 85
Wait until Friz sees this.
Old 04-04-2012, 01:21 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
This is the ultimate vacuum leak tester. Back off the intake and exhaust valves, replace the throttle body with this plate. Apply vacuum to see if it holds. If it doesn't, apply cigar smoke and see where the leak is. There is a cork gasket on the other side which seals against the plenum.
Old 04-04-2012, 09:44 PM
Midnight 85
What a great idea! That would work like a charm
Old 04-04-2012, 10:11 PM
Caboboy
Caboboy's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
'23-'24
What a great idea Will, that should be done on every buildup or reassembly!
Old 04-04-2012, 10:17 PM
gunnerjuju
gunnerjuju's Avatar
that was a gift even though it is true
To bast way to check vacuum leak
Quick Reply: bast way to check vacuum leak
