Where to find headlight motor electrical connectors?
I'm trying to find a couple of the GM weatherpak 5-wire connectors (male). These are the connectors that attach the headlights/motors to the vehicle wiring harness on later model C4's. I've found the female ones on rockauto, but searched everywhere and can't find the male ones. Found 4-pin and 6-pin, but no five pin!
Any ideas?
Thanks!
Any ideas?
Thanks!
Any ideas?
Thanks!
Any ideas?
Thanks!
Dave
Any ideas?
Thanks!
Any ideas?
Thanks!
Yes - they are Metri-pack 280
Search this document for 12084891. Second hit is an image
http://delphi.com/connectors/assets/...es_Section.pdf
Delphi "gender" is determined by the "terminal" and NOT the housing! That confuses some. Which "terminal" is it that you need? The connector/housing is generally the opposite of the "terminal".
Shroud and tower I've never used when doing automotive particularly GM/Delphi, I just try to get it right. I've fixed many situations where the "other" guy got the "wrong" stuff. If you use the terminals that you actually need you'll not "error"!
I understand your effort to help - so am I!
I've never seen "tower" and "shroud" used in Delphi cataloging for anything other than randomly in Weather Pack.
FROM A WEATHER PACK FAQ BY A VENDOR "NOT" DELPHI
Why are the Weather Pack connectors called Towers or Shrouds instead of male or female connectors?
The use of the "Tower and Shroud" nomenclature eliminates confusion with gender specific connectors. Weather Pack towers are most often used with female terminals but they can also be used with male terminals. Weather Pack shrouds are most often used with male terminals but they can also be used with female terminals. It is even possible to use both male and female terminals in a single multi-circuit Tower or Shroud.
You can NOT "mix" in a Metri-pack 280
I understand but if you look again you'll see the 12084891 referred to as a 5F which means it uses a "female" terminal! The 12186400 in the right column is referred to as a 5M and you can see it displayed with "male" terminals in it.
Dave
These people http://www.eficonnection.com/eficonnection/ have alot of connectors listed, and alot that are not listed. E-mail them if you dont see the one you are looking for.
Any ideas?
Thanks!
Any ideas?
Thanks!
http://www.eficonnection.com/eficonn...spx?ItemId=191
Or maybe these guys;
http://www.mouser.com/Delphi-Connect...z0zlezZ1z0x3z0
I believe Dave has him covered or that's the way I saw it earlier!
The OP was a little vague - it's hard to tell if he wants just the plastic connector or terminals and seals also OR if he really wanted a "pig-tail" with wires to cut & splice. It can be done either way!
If you have them that would be awesome! If not, looks like I can piece them together at mouser.com
Thanks again everyone!
I have pulled the pins out of a connector many times and transferred them to a new plastic shroud. Saves a lot of soldering, etc., especially if it's just the plastic part that is damaged.
This site will help you (or maybe confuse you with all their offerings) identify your connectors (direct from the source -- AC Delco). You can do a search based on connector gender and number of pins:
http://www.acdelcotechconnect.com/pi/wiring-connectors/
