Mpg
About 3/4 gallon per quarter mile run.
Better check for leaks or do a serious tuneup that is 5 lbs of fuel.. do some basic math and see how possible that is with less than 2000 hp.............................. If I give you 15 seconds under full power that is 5lbs /15sec *60 sec/min * 60 min/hr or 1200 lbs per hour enough for 2400 hp.. nice engine ya got there ....................................
FWIW: Most people driving a C4 are interested in "Smiles per gallon". OTOH, they can get impressive hwy mileage. It's funny/ironic when people say their vette is their economy car.
I can say for certainty, any long distance I would drive, I'd rather drive the Corvette. With a ZF6, it's easy to beat my DD SUV in MPGs.
But, only on the hwy...when not enjoying what I really own it for!
That said, there a many many threads on this topic.
I don't really care much about MPG other than telling me how truely awsome this thing runs. '94 automatic - 26 MPG highway.
If you read this forum, you mostly read about problems. At the moment, knock on wood, I have the best running '94 on the planet. I'm sure there are faster but none run better.
This very busy and a year old, the truck is running much better this year, but shows the mileage for my L98 for the year I ran it:
Looking forward to seeing how the LS3 does...
Cruise-In II Veteran
What types of MPG ratings are y'all getting? Have you tried anything to improve your MPG?
So far I've done two things to this bone stock '88:
-installed a 160deg T-stat; the ECM will not now call for EGR to pollute the charge while cruzin the freeway.
-pulled the OEM AC/Delco spark plugs and cut back the ground electrodes; this produces a more uniform charge burn for more efficiency.
-tossed the "frisbee" from the front of the water pump pulley; less wasted power == more power to the pavement & better economy.
-on the street I run 35psi around; better cornering and lower rolling resistance than the 30psi that I use for drag racing.
Of course I installed a K&N filter under the cut-back lid but that was more for power than economy.
Next year I plan to have my custom exhaust shop replace the OEM front Y with a 2 1/2" mandrel-bent unit and install a hi-flow cat. Less wasted energy pushing exhaust gas through that very restrictive stock system will gain both power & mileage.
Most engine mods I do are intended to increase efficiency for more power but they (mostly) also bring better mileage too.
My '96 LT4 gets much better gas mileage on the highway (30+) than my '08 HHR (28+) ever thought about doing...the HHR was a work car, thought I was doing good - it could haul a lot more gear, though. So much for econoboxes.
My old CE LT4/6spd gave me a solid 28mpg at 65MPH - higher the flatter and slower I cruised. My new 08 Z06 - close to that as well....
Dave C
71 Demon 340/4spd - 6,750 original miles
08 Z06 Jetstream - 1,250 miles (for now)
Dave C
Or...used his graph for shooting practice after he was done drawing it!
When it had the original 350 - about 7 MPG on the road course
The 383 was about 6
The new 383 should be about the same
The 383 was about 6
Received 3,043 Likes
St. Jude Donor '05
On an aging car you may still get what was est new poss. a little less
How guys are outsmarting the engineers and claiming another 4-5 mpg I will never figure out.
Please tell us these secrets
