New Gears...Hypertech prollem?
I am having 3.54 gears installed and I am going to need to flash my PCM with the change, however 3.54's are not in the option list of my Hypertech Programmer!! Now what?
Re: New Gears...Hypertech prollem? (STL94LT1)
You can set it to the closest ratio, then experiment with using different tire diameters & you CAN get it EXACTLY correct..
In my case I installed 3.73 rear, & the closest Hyper has is 3.70 when I had the stock tires on they were 26" diameter but I set the Hyper to 25.5 & my speedo was dead on..
It may take a few tries but just play with the tire size..
Elite Torch Red Member
Re: New Gears...Hypertech prollem? (Red96Coupe)
I had to do mine the hard way. I actually had to switch the plastic gears in the tranny.
