1992 vette horn button removal?
Old 07-13-2013, 09:24 AM
pushrod-v8
pushrod-v8's Avatar
Default 1992 vette horn button removal?
My horn is not working and I need to check the connection point at the horn buttons on the steering wheel.
Anyone know how to remove the horn buttons without breaking them?
Old 07-14-2013, 01:31 AM
tpfarm
tpfarm's Avatar
I have a 91 so I think the procedure would be the same. I have removed mine a few times over the years and as yet have not broken one. My FSM states this for removal.
1. remove air bag.
2.Push in two lock tabs on edge of horn button and lift up inside edge.
3.Pull horn button inside and up to unhook two hidden lock tabs on outside of edge of horn button.
4.Three phillip screws retaining switch plate to steering wheel.
5. Switch from steering wheel.
Hope this helps.
if you need help with removing the air bag let us know someone will chime in on how to do it. Not a big deal.
Quick Reply: 1992 vette horn button removal?
