Master cylinder upgrade?
I would imagine you could replace it with one from a later model but you might have to cut and move brake lines to fit.
If you have yours off take it to a parts store and look at the later model replacements and see if the lines are the same size, as long as everything measures up it will work.
There's no way to actually check the compatibility "hydraulically" until it's fitted and tested. You need to understand that a purchase and mount of something you're not happy with or doesn't work likely isn't "returnable"!
Have you tried to locate a rebuilt/re-manufactured or maybe even a new for it?
The only mc that are available are those made in china and pricey almost $200.00
GM ones are difficult to find and even more expensive nos.
Haven't upgraded mine since it's not a track car, did buy the centric, didn't install it yet though, turned out the brake booster was faulty, got mine from eckler's pricey yeah but works fine for over a year now.
I replaced my master cylinder on my 84 a few months ago. My parts guy searched throughout the US and found a Bendix (made in USA) unit in Detroit at an auto supply house and had it shipped out here. It cost about $250, but it is new, works as good as new and hopefully I won't have to worry about it for the another 30 years.
I bought a new GM master cylinder. I thought it was interesting that the original was aluminum but the replacement was cast iron. The original was made by PBR in Australia. The replacement was also PBR.
Last edited by Cliff Harris; 07-30-2013 at 03:39 AM. Reason: Added replacement was PBR.
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
If you are willing to put new fittings on the end of your lines, go with a '93-2002 4th gen Camaro master cylinder. It will bolt in place, but needs different sized fitting. They are super easy to come by and are much cheaper than the C4 stuff. Also, the bore is slightly larger which will give you a better pedal in my opinion. I put a used one in my race car several years ago and have not had any issues.
I just put one of these on my 85
http://cgi.ebay.com/ws/eBayISAPI.dll...:CPSOB:US:1123
http://www.partsgeek.com/catalog/198..._cylinder.html
They raised the price on the one I bought($97) but I was brousing and found an 82 dollar one.
But it looks like it is seeping just a touch from the cup seals. and they forgot the low fluid light connector but said they will send me one. Other than that it doesn't really leak FYI
That's not a low fluid light connector. It is a brake balance switch. It turns on the BRAKE light on the center cluster if the front or rear brake circuits have a problem (meaning no or low pressure).
Thanks!
You can kinda see in these two pictures from when I was putting the engine in. If you want better ones I can go out to the garage tomorrow.
