Where to get door 'clips / plugs' in c4 door that the trim screws Into?
Looking for the plugs that push into the door frame behind the trim panel around the door handle area that the screws go into . The door is from a 94. The plugs were missing and 1 was broken so the door trim is pretty loose. Tried a few different plugs but can't seem to get the right size/depth and screw hole size I need.
They are offered by Au-ve-co. They are the oval white plastic inserts...I have them at my shop and can give you a part number tomorrow.
DUB
DUB
The nylon slotted oval insert is a GM # 1377030 and most any dealer will still have them on the shelf. You should be able to find singles at any dealer. In a dealer body shop they likely have them loose in their shop hardware. You will not have a problem with finding them.
10365 is the Auveco equivalent but you'll need to likely buy quantities so the dealer would be my first choice.
Google either number and take the image with you to a body shop or dealer with the numbers. You'll have no problem!
