tachometer problems
Cruising
tachometer problems
good afternoon all. we bought a base 90 a month ago & the tach hasn't worked since. when I put the key to on position - 1000 rpm, when i crank it - 21-2200 rpm, soon as it starts - it pegs it at the bottom. I know with it at 1000 as soon as i turn it on, it needs calibrating. but this pegging it low once it starts i have to figure out. i can build or fix anything. can a capable individual rebuild these clusters? Thanks
There are many threads relating to the problem and also the repair. The search function is best used here - there are way to many threads to head you in a particular direction. I assure you that the search function will work. Good luck.
