Interior lights
Old 11-22-2013, 04:26 PM
Samuelsd
1st Gear
Samuelsd's Avatar
Default Interior lights
I have a 92 vette. The interior lights will not shut off. The door ajar switches will shut off the dash ajar light but the lights stay on. The problem started suddenly.. Any suggestions?
Old 11-22-2013, 04:35 PM
Pete919
Pete919's Avatar
Jiggle the key in the door locks, make sure they are straight up and down. Lot of threads on this. Had the same problem.
Old 11-22-2013, 06:17 PM
xrav22
xrav22's Avatar
The lights are controlled by the pin at the front of the doors.
Old 11-22-2013, 06:23 PM
floridamale
floridamale's Avatar
Spray a little WD40 inside the rubber in the door pins work them in & out by hand a few times see it that helps they can stick.
Old 11-22-2013, 06:39 PM
RollaMo-LT4
RollaMo-LT4's Avatar
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19-'20-'21-'22-'23
Just to state the obvious, make sure the dimmer "slider" on the light switch isn't rotated all the way over.
To Interior lights
Quick Reply: Interior lights
