1986 Emergency Brake Shoes Replacement Inquiry
When I bought the car last year, my mechanic replaced all 3 of the e-brake cables. Even with the cable adjusted correctly, and the shoes adjusted nice and tight, the e-brake will not hold the car from rolling. I'm guessing that something has frozen up inside the rotor, and probably needs replacing at this point. When I pull up on the lever, the cable is probably just flexing vs. actually moving the parking brake shoes.
Car is a 1986 convertible with the 4+3 transmission. Question is, is it difficult to replace the shoes? My main concern is getting the large nut off that holds the rotor on. Do you need an air gun to remove it, or can you just hold the brake pedal down, and use a large breaker bar? I replaced many GM rear drum brake systems in the past, and just wanted some feedback on how difficult of a job it really is. I'll probably order the whole e-brake kit from Eckler's or Mid America, etc. Any feedback is appreciated........
Reagrds, Chris
Reagrds, Chris
- 1986 Original Owner -
Reagrds, Chris
Reagrds, Chris
It's actually in the front on these rotors as opposed to the rear like many other GM cars of that era...........
