zf6 trans oil question
#41
Make sure you can loosen the fill plug before you drain the trans.
#42
Thanks, I am going to pick up the 17mm allen socket to remove the plugs tomorrow. Then I will give it a try.....I have sprayed some wd at the plugs in hopes of making them loosen up a bit easier....I will let you know how it went....
Thanks Russell.
Thanks Russell.
#43
I've i hand ready to fill my 1995 ZF red line MTL, not tested yet , so I'm not be able to say you if improvement in shifting to make , anyway think yes
#44
PS I also replaced my fuel filter while I was down there. 😝
#45
The plugs came out without issue. I drained the fluid. Let it drain for awhile. Cleaned up the plugs and got out my fill hose and snaked it through down past the firewall and refilled with the redline lightweight shockproof gear oil. Talked to Bill from ZFdocs and he said ok to use that fluid. He also said no thread sealant of any kind on the tranny plugs or fill plug. Just torque to 26lbs. It all went just fine.
Allen socket Both 17mm fill and drain?
#46
Reverse gear also is very smooth, before with old fluid was very hard to engage, and sometimes malfunction on back up lights switchhappened, missing to turn on lights, no more
Great smell, typical petroleum, i love it, red colour,
Tomorrow i will re check level, think it will be necessary to add fluid a little, cause today car wasn't on perfect flat surface...
