Flushing Cooling System
Had my entire cooling system redone: new radiator,thermostat hoses etc. My 94 is running 10-15 degrees cooler now. When we did the update we couldn't get a good drain and flush because we didn't have the facility to do it. Do you think it would be worthwhile to take it to a pro shop, have the knock sensors removed, and flush the system correctly?
If you didn't remove the knock sensors, the flush wasn't complete.
Not only do you need to remove the knock sensors to drain that area, but you should direct water under pressure into the sensor holes several times to really complete the flush.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
