89 Corvette with EXH TEMP warning light
Hello,
I am looking at buying a 89 Corvette and the Service Parts Identification label indicates it is a NN5 California Emission car.
Are there any exhaust or emissions parts that are unique to NN5 cars ?
I noticed that just above the headlight switch there is what appears to be a warning light that says EXH TEMP.
The current owner has no idea what this is.
Has anyone ever seen this before and what is it for ?
Hello,
The UD6 option is only cataloged in SPO publications for '84 - '85 and then skips to '94 - '96. Do you have maybe a build sheet for your car? Where is the car located?
Is there a UD6 option or some other unusual U or V RPO's? UD6 is a converter temperature option but I believe it was only done on cars with EXPORT requirements. Do you know if your cluster is original or not?
The cluster says 70K but the interior and exterior looks like 140K miles, very possible as you suggest, the cluster has been changed.
