Rear Sway Bar Bushing Installation Question
Hello all!
I am about to replace the sway bar end link bushings in my 1995 base coupe with a set of Prothane bushings. How do I find out the stock size of the rear sway bar? Is it something I can find out without physically measuring?
Also, I have read countless sway bar bushing threads just to gain knowledge before jumping into the project, but I am still an amateur when it comes to working on cars. Any good tips for this job?
Thanks!
Thanks!
The link below is a good reference for C4 suspensions.
It looks like you should have a 26mm front bar and a 24mm rear bar.
http://www.corvetteactioncenter.com/...usp_chart.html
Good luck.
Good luck.
Why not just buy a cheap dial caliper? You should have one in the toolbox anyway.
