What HP are you making on 24 lb injectors?
would Upgrading to higher pressure pump help the "batch" style fuel injection system?
Cruise-In V Veteran
There have been many discussions on this subject (just do a search). The batch fire fires the injectors once every revolution, this is quite a bit more fuel than the precise control of the injector that is expected of todays computers.
With sequential you fire each injector once per cam rotation.
Because on batch mode you have to fire your injectors more often, they have less time to be open. With sequential you have more than twice the time to keep your injectors open (remember dead time).
Total volume of injected fuel is about the same. with sequential you may even get slightly more fuel since you can run them with higher duty cycle and less dead time per cam revolution.
Cruise-In V Veteran
With patch you fire each injector twice per cam rotation
I also agree that 24 lb injectors should not support 600 HP but is possible if the engine is very efficient. Ford 24 lb injectors are rated at 39.5 PSI since he is running at 42 PSI the injectors are actually running at 25 lbs per hour. An engine making 600 HP with a very good BSFC number of .33 lbs/hp (very rare) could run on injectors of 25 lbs/hr with 100% duty cycle. Since the duty cycle max is only achieved for brief periods of time at or near max power, it is possible.
When I had a stock bottom end, hotcam, ported factory heads, and headers, I made 362hp 376 tq. on factory 22lb injectors. Pressure was stock. But Alvin (pcm4less) said I was maxed out and was starting to go lean. Best times were 11.71 at 117.3 with that combo.
BTW I now have 60lb injectors. Ed Hutchings tuned the motor for both e85 or pump gas. It runs great!! Ed said that the newer, big injectors are no problem to tune if you get someone who knows what they are doing. Again, he did great with mine.
One other point,4WIW, the 2006 ZO6 uses 42lb injectors.
