Broken Crank, Torque Converter or ?
T/C scattered. A cracked vein came apart when you "punched it" and that set off a chain of catastrophic events that got you where you are today.
junk inside now has it completely locked up and bound, jammed and unable to grind itself in the normal rotation any more....that's why it WILL go the wrong rotation a little bit...
trash is now thru the whole trans assembly and probably got the planetary gears jammed and metal in the clutches...junk tends to bind rotating parts. AT hiway speeds, things happen real fast, the devestation spreads in seconds.
Get the TC bolts out and see what is locked up and whats NOT.
Good luck, prayers for the 396 !
The transmission would be the least expensive option at this point. The Vigilante converter is under warranty. There's a local shop I trust to rebuild the transmission.
On the other hand, the engine would be major. There's only one guy (Jim Barth) I trust to rebuild it. And I know that once we start down that path there will be upgrades and more power, maybe a 421 and well, you get the drift.
Seriously doubt the crank broke.
Sounds like the converter puked and caused the front pump to lock-up. This usually rings the drive ears off the converter snout or breaks a pump gear and it can cause the flex plate to fail also.
Usually if converter failed, the metal will stop in the pump gears and the transmission should be fine with a new front pump and a converter. Good luck!
I think that it's pretty hard to get junk throughout the trans if a torque converter fails. The oil coming out of the converter goes straight into the pan, so no problem there.
Any ATF going through the pump comes directly from the filter because the filter is mounted in the pump inlet. As I showed in post #9 in this thread, my filter was full of metal particles but the oil in the pan had nothing in it.
Kind of sounds like a planetary gear may have given up the ghost on you. I got away from the 4L60 transmissions long ago but that was a pretty common failure when we ran them. When they exploded things went down hill in seconds...just my .02 and best of luck with it!
Here's an update. I tried to remove the torque converter bolts. But I can only turn the engine about 1/4 revolution. There's no way I can get to two of the converter bolts. The transmission is obviously coming out. But the question is can I pull the transmission with the converter still bolted to the flex plate?
#33
yes, since odds are your trans is toast any damage that could happen to your front pump or torque converter is moot, its a little tougher because the converter might hold it in place a bit, and the trans will be a little tail heavy because the converter wont be there as a counter balance.
#34
#35
Are the rear wheels off the ground, and the trans in neutral, and the engine still can't be rotated?
If the tc is locked up internally, I don't see how you could have pulled to the side of the road with the engine still running, as if the trans was in neutral.
#36
Yes I have the rear wheels off the ground and in neutral they turn fine.
#37
So, does the driveshaft turn when the trans is in neutral?
#38
No, the engine will only turn about 1/4 revolution. The driveshaft does turn in neutral.
#39
at the end of all of this the cause will probably be a shattered front pump, right now there are bits of the front pump have the front half of the trans jammed up in the pump, so the back half will allow the wheels to spin.
#40
This is getting really interesting. Hopefully, we can learn from this. I had a broken piston in an engine I was pulling, but was able to pull the head and take the broken pieces out. That allowed me to rotate the crank and take out the torque converter bolts. How do you get this apart?
Any transmission specialists following this thread?
