Inside Air temp sensor electronic A/C
Anyone have any info on inside air temp sensor P/N 16041001. Is there a way to test them to see if they are any good. And is there anywhere to buy a new one. Apparently they are discontinued so not readily available. Thanks.
If you put the HVAC controller into diagnostic mode it will tell you what it is seeing from that sensor. Some info on that:
http://forums.corvetteforum.com/c4-t...stic-mode.html
You should be able to measure the sensor with an ohmmeter. From what I've seen, all the sensors in Corvettes have the same response curve, so I think this chart would apply:
