laptop for an 85
laptop for an 85
OK, I had my birthday.....wife got me a laptop because she's heard me talk about tuning....I know i've asked this question before but can't dig it out of the archive....I'd ask on the 'turner" side but I can't understand the questions, let alone the answers....I need some tuners for dummies help....I know I need a aldl cable and guess I should download the "tunerpro" software into the laptop.....anything else I need to get started?
I thought I remember something about "Moate" stuff....can someone get me started......please remember you're dealing with a person who thinks computers make good boat anchors......
Happy birthday.
I am in the same boat. I am thinking of tuning mine also, but don't know a lot about it either.
I think it was "Moates" instead of "Moate".Try looking at the following link for the cables and stuff I was looking at.
https://www.moates.net/gm-19851995-c-64.html
Good luck.
Good luck.
thanks, that's the site I was thinking of....still really don't know all that I need....looks like there's choices of the aldl cable....hopefully one of the experts will chip in......
Happy birthday.
Good luck.
Good luck.
ALDL cable
First question before buying the ALDL cable. Does your laptop have a 9 pin rs232 (serial) port? Probably not as "most" new laptops do not have it anymore. If no, then you need a USB to ALDL cable. You can look here. Sorry, I do not have any experience with Tunerpro, but I do not believe that it supports the slow data transfer rate of your 85 vette ECU that is 160 Baud. WinALDL is one that will. Good luck!
I've been through this. If you haven't done so already, you will need to install a chip adapter in the ECM. It needs to be soldered in. I highly recommend you send the ECM to Moates and they will install the adapter for $25 and provide you with the flash chips. I also recommend buying their socket booster. It plugs into the adapter and boosts the signals. I also recommend you get a ribbon cable and a ZIF adapter. That will allow you to remote the chip so you don't have to remove the ECM to swap chips. Moates can also sell you the ALDL cable.
TunerPro will work with the 85. If you download the older version it is free.
If you really want to get into tuning, upgrade to a 165 ECM. I waited too long to make the swap. It's a lot easier to deal with.
This link has enough information to keep you busy for a LONG time:
http://www.thirdgen.org/forums/diy-p...uide-book.html
What is better about going that route?
What more do I need beyond the 165 ECM to make the swap?
Just getting into making a bracket racer out of my 85 and want to do it right the first time...so I am open to any suggestions that will work and make life easier.
I use this setup on my '85
http://www.reddevilriver.com/aldl.html
The best advice i can give is, get a teenager to help you set it up !!
This page may help some of those reading this.
http://support.moates.net/gm-86-95-obd1-guide-read-me/
Makes me wonder why I bought an ALDL cable instead of a learning ECM (ElectroMotive?). I know the newer ECMs are faster, with more capability, and that they all strive for stochiometric fuel burn, within their adjustment authorization. I stopped that activity when my laptop would not 'speak to' this ECM.
Then, I speak to my pal Roy, who simply runs an unmodified ECM/chip in his header-equipped, ported-CFI '84 L83! His car is surprisingly fast and passes CA smog easily, even with 200k+ miles. Maybe the benefits of many chip changes for novices are overblown?
