advice please!
Suggest checking the throttle shaft to housing clearance they tend to wear in that area otherwise they are golden.
The RPM limits for a l98 engine are primarily due to the intake manifold design, small heads + small exhaust however they produce 350 ft lbs of torque from the factory. They are great street engines when tied to a 700 auto trans. If twisting the snot out of it & using a manual trans is the goal the intake, heads, cam & exhaust will need to be changed + a dyno tune to burn a new prom.
Stock 48mm throttle body flows about 780CFM it will operate well until the CU IN is increased, cam & larger heads, intake manifold, exhaust etc are changed.
what if i just wanna hop the motor up a little bit? what do you think i should? my goal is for it to be a show truck but i want it to sound good and have a little bit more power then stock ya know? and im gonna be running the stock 700r4. i was gonna hace a shift kit put in the trans. thanks!
A bigger cam can be added later if the need arises but with a bigger cam you will also need a higher stall speed converter + a tune.
The 700r4 has a 3.06 first gear, couple it to a rear gear in the mid 3's
& you can easily melt the hides & impress the kiddies. A shift kit is ok in my book.
The l98 engines sound good with long tube headers & dual exhaust.
Header selection is limited with the aluminum Vette #113 heads they have 3/8" raised exhaust ports like the Chevy ZZ4 heads. A set of Vette headers should fit your truck chassis or Patriot H8055 will fit the Vette heads however they are 3/4 length. The Patriot H8055 are designed for a tri-5 Chevy they fit tight/close to the engine.
Suggest freshening the engine & leaving it basically stock. With 350 ft lbs of torque you will be pleasantly surprised at how good they pull from idle to 4800 rpm.
2021 C4 of the Year - Modified Finalist
If you have the money and want to keep the TPI look you can get a FIRST intake.
https://www.firstfuelinjection.com/services.html
