1994 Vette serp belt diagram
This should be simple. Does anyone have a diagram of the serp belt routing? I did check the search and no diagrams.
www.volvette.com/4DC035P.html
The label should be correct for all single-sided serpentine LT1 applications through '95.
This is what I am using on my '96. I believe your '94 should be the same.
Gates Micro-V AT® - Serpentine Belt
Part Number: K060670
UPC: 72053248265
13/16" x 67 1/2"
Section: K
Number of Ribs: 6
Top Width (in): .807
Top Width (mm): 20
Outside Circumference (in): 67.543
Outside Circumference (mm): 1716
The pulley just above the crank (with the arrow showing that it moves up), is the spring loaded tensioner pulley. It moves up in the direction of the arrow in order to allow you to replace the belt.
Make sure you have the belt routed correctly.
Diagram from the FSM for a '96 belt routing.
UPC: 72053248265
13/16" x 67 1/2"
Section: K
Number of Ribs: 6
Top Width (mm): 20
