fuel injectors for 415ci
What do you all think? Building a 415 stroker and wondering what size injectors would be best.
Mini ram intake
afr 220 comp port heads
tpis zzx cam .240 .240 .597
I'm thinking between 550-600 crank HP...
Mini ram intake
FIC has several slick calculators on their web-site.
Plug in estimated peak HP, fuel pressure and duty cycle (there may be one or 2 other values) and it will tell you what you need.
I'm using 36lb injector on my 406 spinning to 6800 running 10.20s with room to spare. Miniram with a similar cam to yours.
