94 lt1 6 speed asr issues
My 94 is sputtering randomly. The service lights are on for the asr and the abs. Sometimes it performs with no issues and other times it sputters and hesitates. Any ideas? Could the asr cause this?
I have and it looks good. Going to check it again this evening. I am thinking my sputtering problem is with the MAF sensor and the service lights are a different problem but i am not sure.
Pro Mechanic
Put a jumper wire in terminal A and G in your ALDL connector, and pull the ASR/ABS code. Then we can diagnose rather than WAG.
I am still voting on th cause being low on brake fluid. My car would throw the ABS light and the Service ASR light under heavy acceleration and it was because it was slightly low on brake fluid.
Brake fluid is below the max but above the min. Could definately be what you are saying. Still no spitting or sputtering since MAF has been unplugged but a definate loss of power from somewhere and check engine light. My best guess is this is due to the MAF being unplugged. Thoughts?
Pro Mechanic
Yes, I have some thoughts:
The Check Engine light is on b/c your MAF is disconnected.
The ASR/ABS light is NOT on b/c of a missfire, or any engine drivability issue.
When does the ASR/ABS light come on and stay on?
*As soon as you start the car?
*As soon as you move the car?
*When you hit the brakes or accelerate hard?
Pro Mechanic
It varies. They're staying on 75% of the time. Sometimes they come on the minute the car moves. Other times they do not come on until i accelerate. Sometimes they stay off for a while and come on during normal operation. Another thread on this forum pointed me towards a wire in the driver side rear wheel well. Im going to pull the wheel and inspect this over the weekend.
Put a jumper wire in terminal A and G in your ALDL connector, and pull the ASR/ABS codes.
Thats my next move. Just have to find the time. Ill post an update when i find the problem. My main concern was the engine performance. I think I have tracked that down. Thank you all.
This was after a can of cleaner on my throttle body.
This was after cleaning with another can and soft cloth. MAF sensor was really bad too.
Update on ASR and ABS lights. Topped of brake fluid and lights went off. Im still going to investigate the wires in the driver side rear wheel well.
