No power at high speeds
Well that test pretty much answers the fuel pressure issue, looks like it is not the problem. Something odd happening beginning at 3100 RPM, if not the cat then valve springs/cam issue? I think you are right to check the cats next.
Thanks again for any help,
Kevin
Sorry, I didn't mean to imply when I mentioned the EGR valve and referenced the cats that the EGR valve was the culprit. I saw it as a potential sign: if the EGR valve is bad, it's possible that it failed as a result of a bad cat. Cat test should just be as simple as remove it, see if any of the honeycomb falls out, look through it for any debris, then reinstall.
Thanks for the reply and the help,
Kevin
Do you have stock exhaust on there? You shouldn't have to cut out the cat, it should be bolted on.
It should be:
Mainfold -> Front Y-Pipe -> cat -> rear y-pipe -> muffler -> exhaust tip
Check this diagram out:
http://keenparts.com/Graphics/diagrams/15025.gif
The exhaust should connect at the cat, then seperate again (keeps it from being a true dual-pipe exhaust, but it is what it is)
It should be:
Solved.....
Hello All,
I was able to remove my main CAT today..When it came down a collection of honeycomb material fell out at the front of the CAT before the screen. I assume that material came from one of the front pre- cats. I couldn't see through the converter so I began to hollow it out for now. I could not see through most of the honeycomb material that came out in big chunks. Put it back together and now it runs like it should...much improved power and acceleration. No stumble at 3000 RPM's. After a while I got a SES code. I assume it is converter related. What is the consensus here in regards to a hollowed out CAT? Should I replace with a new one? Not too worried here in PA as emissions for this year is a visual only.
Thanks very much for all of the help along the way,
Kevin
Kevin
Hello All,
Kevin
Kevin
Glad it wasn't too difficult to diagnose!
Thanks for the reply. I still need a new EGR valve. The hose is currently blocked. I was going to swap it out last weekend but I was so happy it is finally running well that I drove it all weekend. I have a more pronounced drone now but as of now don't mind it much. Its pretty much a weekend driver.
But at least it runs better than before, one problem solved!
Cruising
Fuel pressure looks ok. Although I don't know what you mean by "accelerated to WOT...." Does that mean you gradually pressed the pedal or that you accelerated at WOT to a certain speed?
So check for exhaust back pressure. Also make sure that it is timed correctly. My '84 you have to pull a certain wire or it will actually be retarded several degrees. I know because I pulled the wrong wire. When I found the right one, I needed to advance it about 16 degrees to get the right setting. It behaved as you described until it was right.
Holes in exhaust generally won't cause back pressure. Baffles coming loose in muffler will.
