fuel pressure 31psi
fuel pressure 31psi
After the car gets above 190 degrees it stumbles and will stall at a stop.
My '94 vert's fuel pressure is reading 31-37 psi. Should be 45psi right?
This should just be a fuel pump change, not the fuel pressure regulator...
Thanks as always for the advice!
C
C
My 94 is 40- 43
It should be around 41 psi with the vacuum line disconnected. If the line is connected it will be in the 30's at idle.
