Unknown vacuum port, 89 auto trans
I can't figure out what connects to the large vacuum port on the passengers side of the throttle body. Not the pvc port. I know what connects to the small vacuum port on the bottom of throttle body. I am thinking the large port connects to the charcoal can, but it's such a large connection at throttle body and a very small plastic line at can. While I'm thinking about it can I replace all those brittle plastic lines with rubber hoselines, will it hurt anything?
The fpr line connects to a small connection device right behind the tb and then to the small lower port on tb. Am I correct?
There are three connections on pass side.
Water hose
PVC valve
Unknown
Maybe someone could look at theirs and let me know
I took off TB to clean it, and cant remember what was connected there
Water hose
PVC valve
Unknown
Yes that helps. Thanks. Still would like someone to look at theirs and get back we me if they wouldn't mind. Also still need to know if I can replace with rubber hose instead of plastic. Again, thanks to all. Trying to do most of work on car myself
hose with a 5 dollar 1 into 2 one way valve, then the hvac hooks up to one outlet and the other goes all the way across to cruise control splitter to ball and cruise unit. Mine is an 85 so of course yours may be different.
Good luck
gasandvetteman (02-07-2019)
Same plastic line as the air switching valve uses. It pops up from the loom and goes next to the distributor. It may be missing or altered but it may have cracked off down low, mabey even fell off and is pointing downward. In the loom I can't say which way it travels exactly.
This all changed from year to year, so this might not apply to you...
