dash problems
dash problems
So I'm new to vetted and I just purchased an 89 with a new MTR that someone converted to carburetor the problem I have is now the gauges and speedo are connected and the dash all lights up but none of the gauges read I checked fuses and the pigtail connection at the gauge cluster still nothing help pleasr
The speedo should work if the same transmission with the electronic speed sensor is still connected, the tacho needs to be wired to the distributor.
Is the ECM still there? can you see any temperature or fuel level display?
Can you see the dash display with sunglasses on?
The dash can fade due to UV and heat damage and Batee has the repair kits if that is the case.
Click the link below to batee's website, there is lots of info on the common failures.
http://www.batee.com/
