starting
Old May 3, 2015 | 12:09 PM
Pellno1's Avatar
Pellno1
Default starting
Hi
Sometimes I get a clicking sound,sometimes I get a loud buzzing sound for about 30 seconds then sometimes it just starts on my 87 vet.When I get the clicking sound if I keep trying it will kick in and start.The loud buzzing sound is puzzling.This is on my 87.Battery is good,new starter about 2 years ago.
Thanks Jim
Old May 3, 2015 | 12:56 PM
antfarmer2's Avatar
antfarmer2
Originally Posted by Pellno1
Hi
Thanks Jim
Check your connections if good and still does it smack it with a hammer if works then get another starter
Old May 4, 2015 | 03:38 AM
Cliff Harris's Avatar
Cliff Harris
You have the symptoms of a bad connection between the battery and the starter. Check BOTH ends of the battery cables.
Sometimes a problem like this can be caused by bad contacts inside the starter solenoid.
Old May 4, 2015 | 04:23 AM
ricasso's Avatar
ricasso
Sounds like a bad solenoid to me..if it were just a bad battery connection the engine would stumble intermittently and your lights, dash etc would flicker also.
To starting
