smokin at idle
Old May 2, 2015 | 08:52 PM
prostreeter's Avatar
prostreeter
Default smokin at idle
i have 89 c4, runs great no smoke on accelration, if i stop with engine running after about 3 minutes it starts to blow smoke out tailpipe, looking for ideas to problem.
Old May 2, 2015 | 08:55 PM
crowz's Avatar
crowz
Well smoking at idle or deceleration = valve seals. That is if its oil smoke.
If its steam then its cracked head or blown head gasket.
Hold you hand at the tail pipe while its smoking. If your hand gets wet its probably steam. If it doesn't its probably smoke.
Old May 2, 2015 | 09:05 PM
prostreeter
Default smoking
it dosen,t smoke on start up
Old May 2, 2015 | 09:56 PM
crowz's Avatar
crowz
Still might be valve seals.
Old May 3, 2015 | 02:49 PM
Corvette40's Avatar
Corvette40
Old May 3, 2015 | 05:47 PM
8a8mfh's Avatar
8a8mfh
It's valve seals. Probably guides too.
At low rpm the oil coming out of the pushrods can flood the rocker pivot area then run down the valve spring and get on the valve stem and get sucked in by the high idle vacuum.
At higher rpm the oil splashes around more and doesn't get on the valve stems so much and theres not as much vacuum.
And it might not smoke at start up because theres no oil sitting around the valve seal area. Let it idle for a while before shutting it off, it'll smoke on start up.
Old May 4, 2015 | 09:25 AM
prostreeter
Default smokin
thanks for input, i felt it was the problem just wanted more than my opinon, bill
To smokin at idle
