86 C4 MAF Power & Burn-off Relay P/N#'s
Just thought I'd throw this information out there for those that might need it... if you're looking for the 1986 (86 only!!) Mass Air Flow sensor power and burn-off relays, here's a GM part number / NAPA part number reference for you:
MAF Power Relay: GM #10067925 is NAPA #AR227 (Echlin)
MAF Burn-off Relay: GM #10094701 is NAPA #AR255 (Echlin)
Thought someone might benefit from the research I had to go through over the weekend.
The following 2 users liked this post by monsolo2:
3D-Aircrew (02-02-2018),
weightlossstar (01-30-2023)
Sometimes the AC Delco part numbers are easier to find (and usually cheaper):
10094701 - AC Delco 212-305 - Relay, MAF burnoff
10067925 - AC Delco 212-300 - Relay, MAF power
Remember to check the dates on threads...this thread is from 2015. :-)
