What correct MAF symptom ?
1989 auto
What should happen when I unplug MAF with engine at idle?
My engine just quits. Is that what should happen? Trying to run down rough idle problem
No vacuum leak
New cap, rotor, plugs, wires, spark control inside HEI, CTS, IAC, new injectors, fuel pump, FPR, timing right on, idle speed set
I know I need new altenator because charging light sometimes comes on at idle. I rev it and it goes away. Goes down to 11.7 volts at times
No vacuum leak
