Lifter Ticking
Old 05-27-2015, 07:11 PM
marvinator
marvinator's Avatar
Default Lifter Ticking
I have a 383 stroker motor . ****** thumper comp cam . 1.6 roller rockers. I have both lifters ticking on number 7 cylinder. tried readjusting to no avail. noticed they weren't oiling whoops. pulled off rockers, checked oil hole, pulled out push rods checked oil holes,all clear.Any ideas would be appreciated .
Old 05-27-2015, 09:45 PM
jv9999
jv9999's Avatar
What's your oil pressure? The rockers are the last to get oil.
Old 05-28-2015, 06:39 AM
WW7
WW7's Avatar
One of the most common causes of a lifter ticking is the oil hole in the lifter being clogged by dirt or debris.The holes in lifters are very small (1/64") and it doesn't take much dirt to clog them.....Run something like "Marvels Mystery Oil" or one of the other name brand cleaners through the engine as per instructions, this should break the dirt loose and get the motor back to normal....If it's not the oil hole being clogged, then it's time to start looking at mechanical issues........WW
Old 05-28-2015, 10:17 AM
marvinator
marvinator's Avatar
Oil pressure in 65 lbs.
Old 05-28-2015, 10:23 AM
marvinator
marvinator's Avatar
I ran a wire through the rockers and pushrods . didn't feel any blockage. Engine only has 2500 mi since build. changed oil at 500 mi, and again at 2000 mi. really hate the idea of pulling it apart already.
Old 05-28-2015, 10:28 AM
WW7
WW7's Avatar
If it's dirt in the lifter a wire won't do any good ,you can't get to it....Do like I suggested and run some cleaner through the engine..If it's dirt the cleaner may break it loose and flush it out..Since it's a new build the chances are very good that it's dirt....Who knows , maybe the $8.00 investment will stop the ticking.....WW
Old 05-28-2015, 10:34 AM
marvinator
marvinator's Avatar
If it's dirt in the lifter itself a wire won't do any good ,you can't get to it....Do like I suggested and run some cleaner through the engine..If it's dirt the cleaner will probably break it loose and flush it out..Who knows , maybe the $8.00 investment will stop the ticking.....WW
Ok I will try that . Thanks.
Old 05-28-2015, 06:45 PM
gerardvg
gerardvg's Avatar
You may have bad lifters or a blockage, you may have to remove the inlet manifold and replace the lifters (put them in an oil bath first) before your roller rockers WEAR OUT. You can be surprised how quickly the pushrod can wear through the aluminum roller rockers without lubrication.........
Old 05-29-2015, 04:30 PM
Kevova
Kevova's Avatar
You could try putting #7 cylinder at TDC loosing rocker arms and use engine/oil pump priming tool to see if it will start to oil prior to taking engine apart. Just a thought.
To Lifter Ticking
Quick Reply: Lifter Ticking
