LS 376/480 - Backfire Issues?
I posted this on the C3 Tech Forum, but thought there might be an expert on this Forum that doesn't comment over there --- I have an LS 376/480 crate engine in my 1970 Corvette restomod. The engine runs great, but I'm experiencing a "popping" and "crackling" sound when I decelerate while the car is in gear. Sometimes, I even get one or two "backfire" pops. What is causing this? Can it be tuned out of the engine? The car has a stainless steel Magna-Flow exhaust system that has been installed by a pro, so I know there's no flow obstruction or other problems. Could it be inadequate air intake through the K&N filter setup? Help ...
Ive seen something similar with spark plug choices. If its too long it will cause ignitions with out actually being fired. I had all kinds of popping like that with torque master plugs I ran once. Great under full throttle but a royal pain at cruising and slowing down.
Pro Mechanic
Yes, If you tune so that DFCO enables sooner on decel, there will be no fuel while decelerating, to cause the combustion.
Uh Oh. A "professional"? That always raises a red flag for me! I'd carefully inspect the entire exhaust system for leaks, from the manifolds (including any AIR plumbing) to the mufflers.
The "pro" who did my exhaust is a real craftsman, so I'm not too worried about the quality of his work, but I'll still have it checked. This guy has 40+ years experience as is the "go to" shop used by all the classic car people in my area. He is the only one who touched my car and he did the whole system from front to back, with beautiful welds (no clamps or connectors anywhere). Everyone who's seen it says, "Man, your exhaust is a work of art"!
This is common with LS1s in the C5 Corvettes that I have noticed. I think it comes down to the free flowing exhausts that people install on them. Seems pretty common if you google it.
Well anyway, if it's not a mechanical problem it can be tuned out. DFCO, throttle follower, decay rate, etc. Closed throttle timing. Although I do believe it's normal.
Did you ask him what might cause it? 40 years is a long time, one would think he'd have been asked that before.
I appreciate your input and help!
Pro Mechanic
It's normal in that most if not all C5's and C6's will do it. My C6 did w/stock exhaust...more noticeably w/mufflers.
A couple people have already told you how to fix (eliminate) it....
