Torque Specs for 94 LT1 Intake
Old 08-17-2002, 02:48 PM
MarkC5
MarkC5's Avatar
Default Torque Specs for 94 LT1 Intake
Does anyone have the torque spec for the intake bolts as well as the sequence. Thanks
Old 08-17-2002, 02:55 PM
STL94LT1
STL94LT1's Avatar
Default Re: Torque Specs for 94 LT1 Intake (MarkC5)
35 ft. lbs./48 nm. Do this in three graduated steps.
Old 08-19-2002, 03:28 PM
SPD DMN
SPD DMN's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
You want to do it in at least 2 passes. Set the first one to simply snug the bolts down, then the second one for the final torque number. Start in the center and work your way in a circular pattern around the intake.
To Torque Specs for 94 LT1 Intake
Quick Reply: Torque Specs for 94 LT1 Intake
