Blm adjust
Old 10-12-2015, 08:55 PM
Billygoatkid
Billygoatkid's Avatar
Default Blm adjust
Hi!
So thanks to people on this site I've adjusted my overall blm from being rich, to something that is very close on my tune. Now I'm curious what you think on adjusting one cell . Do I use the Maf vs voltage setting or go with the pw vs load?
It's basically only one cell at the 1600 rpm that is a bit rich.
The car runs really strong and I'm still running stock timing till I get the blm's right.
The pic shows a bit lean up top but not to worry. It was with a ten % injector increase which I have made adjustment for.
Old 10-13-2015, 05:16 PM
tequilaboy
tequilaboy's Avatar
You can reduce the low pulse width injector offset table values below 1.708 ms to target the problematic region.
If you have any ethanol in your fuel, you may also want to enrichen the stoichiometric AFR accordingly.
Billygoatkid (10-15-2015)
Old 10-13-2015, 09:26 PM
Billygoatkid
Thanks again Tequilaboy !
I'm learning.
Goat
Last edited by Billygoatkid; 10-13-2015 at 10:35 PM. Reason: Happy face didn't work
Old 10-14-2015, 10:32 PM
Billygoatkid
No ethanol in premium fuel here. How does this change look? It's getting colder here and plan to data log if it warms up, hopefully soon.
Old 10-15-2015, 05:25 PM
tequilaboy
tequilaboy's Avatar
The table you have shown has no effect unless you uncheck the Base PW Calc method switch...which changes (almost) everything with respect to fueling. This method has its own merits, but would not be recommended in this case.
I was referring to the injector low pulse width offset table:
; LOW PULSE WIDTH INJECTOR OFFSET
; vs BASE PULSE WIDTH
; Dissassemby of abtc, LINES = 15
; 12-10-1995, 20:21:35
; TBL = 65.536 * Msec
ORG $03C3 ; Msec Msec
LC3C3 FCB 18 ; 0.275 0.488
LC3C4 FCB 15 ; 0.229 0.732
LC3C5 FCB 13 ; 0.198 0.976
LC3C6 FCB 10 ; 0.153 1.22
LC3C7 FCB 8 ; 0.122 1.46
LC3C8 FCB 5 ; 0.076 1.708
LC3C9 FCB 3 ; 0.046 1.95
LC3CA FCB 1 ; 0.015 2.197
LC3CB FCB 0 ; 0.000 2.44
LC3CC FCB 0 ; 0.000 2.685
LC3CD FCB 0 ; 0.000 2.929
LC3CE FCB 0 ; 0.000 3.17
LC3CF FCB 0 ; 0.000 3.41
LC3D0 FCB 0 ; 0.000 3.66
LC3D1 FCB 0 ; 0.000 3.90
Old 10-15-2015, 06:08 PM
Billygoatkid
Ok, thx for clearing that. Would you suggest reducing the values below 1.708 by 10%?
To Blm adjust
Quick Reply: Blm adjust
