1990 Corvette Oil Pan Question
Old 12-07-2015, 11:42 PM
chstitans42
TheCorvetteBen
Support Corvetteforum!
chstitans42's Avatar
Default 1990 Corvette Oil Pan Question
In the near future I will have to replace the oil pan in my mother-in-law's 1990 Convertible. I am looking to buy this oil pan here from Auto-Zone.
http://www.autozone.com/external-eng...1704_0_107416/
Looks like a great deal but I am hung up on one issue. The internet page says it does not come with an oil level sensor hole. Do 1990 Corvettes need that? I don't have the car with me yet so I cant just look under the car and verify.
Thanks!
Old 12-08-2015, 12:29 AM
hgoodwiniii
hgoodwiniii's Avatar
Thanks!
Get as original as possible unless you are upgrading. These cars are babies. 3 month warranty? Is that a joke? I'm looking at pulling my oil pan from my C4 tomorrow; Looks pretty tight between the engine and crossbar.
Old 12-08-2015, 08:36 AM
aklim
aklim's Avatar
Received 2,240 Likes on 1,947 Posts
Thanks!
MIL: Mother In Law or Malfunction Indicator Light. Coincidence? I think not.
Why buy that junk? You are going to have to measure the height, assuming the shape is exactly the same and not from some F-body or other, drill the hole and all that. There IS a sensor in my 91 and I am fairly certain it extends to 90.
Old 12-08-2015, 09:13 AM
antfarmer2
antfarmer2's Avatar
to early for you? no remark on the sensor hole?
Old 12-08-2015, 09:23 AM
aklim
aklim's Avatar
I kept the 3 hole version for myself.
Old 12-08-2015, 09:33 AM
aklim
aklim's Avatar
I got someone to do it for me since I didn't have a lift. Took some work to get the pan (Miloden 7 qt, IIRC) out. We had to drill a hole and guess at volume for the height.
Old 12-08-2015, 10:18 AM
hgoodwiniii
No lift here either; Looking forward to it. LOL.
Old 12-08-2015, 10:28 AM
chstitans42
TheCorvetteBen
Looking online, 1990 does have an oil sensor. So I need a one piece rear main oil pan with a oil sensor hole. These are harder to find that I thought they would be. Anyone have a used one laying around?
Old 12-08-2015, 10:57 AM
aklim
aklim's Avatar
Have you checked into getting an OE unit even if it is old? You could sandblast and powdercoat it.
Old 12-08-2015, 11:08 AM
WVZR-1
WVZR-1's Avatar
Received 2,262 Likes on 2,025 Posts
OP - The reason for replacement is what/why?
Old 12-08-2015, 11:12 AM
chstitans42
TheCorvetteBen
MIL went to ntb for an oil change, they stripped out the drain plug, leaked like a sieve. I installed am over sized plug which fixed the leak. MIL didn't learn from the first time and went to Wal-Mart for another oil change. They stripped out the over sized plug and now it leaks like crazy again. And you wonder why we all insist on changing out our own oil.
Old 12-08-2015, 11:24 AM
antfarmer2
antfarmer2's Avatar
just get a timesert or something like it.
Old 12-08-2015, 11:46 AM
WVZR-1
WVZR-1's Avatar
TimeSert ® actually does drain-plug repair BUT have you maybe gone beyond using an OS "off the shelf"? Maybe. You'll need to measure and evaluate the dimensions presently and decide which BUT is likely doable and the preferred I'd think.
http://www.timesert.com/html/drainplug.html
"AF2" this time got a "good guess".
Old 12-08-2015, 11:54 AM
aklim
aklim's Avatar
Wal*Mart or any of the quick lube places strip a drain plug? NO!!! I don't believe it. Why, I think they do it by hand with a torque wrench to be sure. I also have a bridge for sale. Slightly used, well maintained and one owner. CASH ONLY.
Old 12-08-2015, 12:26 PM
antfarmer2
antfarmer2's Avatar
did I **** in your cheerios?
chstitans42
TheCorvetteBen
Believe me, she has already gotten "the talk" for a second time. Only bring your car to me to get the oil changed.
Old 12-08-2015, 12:45 PM
aklim
aklim's Avatar
As the song from Meatloaf goes, "Two out of 3 ain't bad"/
Old 12-08-2015, 05:54 PM
70ZZ3 96LT4
70ZZ3 96LT4's Avatar
Default OE pan
Did you check with a GM dealer to see if the OE part is still available? When I checked on a replacement oil pan for a C3 the replacement pan has the drain plug on the drivers side of the oil pan, not in the back like the original. GM did not have my C3 oil pan. Automotive parts stores did.
Old 12-09-2015, 05:09 AM
Tom454
Tom454's Avatar
"OS" means over-size.
There are double OS plugs as well. 2-OS
FYI
To 1990 Corvette Oil Pan Question
Quick Reply: 1990 Corvette Oil Pan Question
