L31-R swap damper questions
I'm about to swap the cam out in my L31 crate motor and I have concerns with timing marks and the damper size. The crate motor has a 8" damper (too big), I want to run a 6 3/4" damper with an external timing tab to make things easier. From what I've found, the stock damper is shorter to make room for the timing ring behind the timing cover. I didn't really want to delete it but I will if need be. Does anyone know if running a normal damper, with the timing ring removed, will clear the Vortec timing cover? Thanks for any input!
I have an l31 crate motor also I just used a normal harmonic balancer for an l98 and swapped to a regular 350 Chevy timing chain cover. I just took the little timing thing out and had no issues.
sansonic How does that L-31 pull? Are you using same cam or did you switch to a different one. What about the heads are you using 113's? I'm thinking off using the same motor. TIA
Question about machining the hub, will there be an issue if I get too much machined off the new hub? Does the hub hold the ring in place? I'd like to save it if I can so I can run a better ignition system in the future.
Be aware a Corvette water pump will not clear the Vortec timing cover, you'll need spacers to make it fit and shims for everything else to get the pulleys to line up.
I had looked at doing the zz4 crate motor but the price is just crazy! The 87 l98 I had in the car before would smoke on start up and couldn't spin the new 17 inch rear tires I put on but the vortec can pretty easily. Plus now I do have the option if I want to go back later and beef this motor up I could do the cam and some other stuff for more power. If your just looking for an engine that will run forever and be reliable then you would like the motor.
