Removal of 86 C4 drivers window & motor
Hello all,
I am in the process of changing out the drivers window motor on my 86 C4 coupe. It is the earlier style with the ribbon type mechanics. I have removed the nuts and bolts that hold the mechanism in the door and removed the two nuts that hold the window on as well.
Here's where I need your assistance. I cannot get the window out. I removed the rear stop and attempted every angle possible. Do I need to remove the bolts that pass though the glass? Is there a special tool for this?
Any assistance would be greatly appreciated. Yes I checked YouTube
Dale Brown
Dale Brown
the two bolts that hold the regulator to the glass? Oh, yes. They need to come out.
Should be a 10mm... it is on the later style.
There are also 2 bold under the door edge... or might be? I haven't messed with the ribbon type in a few years.
ktnrider39 (04-26-2016)
http://webpages.charter.net/khasting...windowreg.html
I used a few pieces of heater hose to make my bump stops/
Good Luck
