Adjusted Throttle Position Switch, won't start
I had to remove my throttle position switch to replace a (Callaway only) fuel line that runs under the plenum on my 87. When I reinstalled, I followed the procedure and set it to read .54 volts. Now the car won't run. It starts and runs for about one second, then dies.
It ran fine before I changed out the line. Not perfect, but fine.
Suggestions? This is frustrating!
Frustrating little booger this has become...
OP -
***Here's the thread that also includes TPS adjustment. Try the TPS "in hand" as suggested also I'd think reasonable. Are there any Callaway specs that need accommodated?
The thread #1 is a repost of some very good information that had been removed in some fashion by "updates" or whatever. The TechTip was very old, very old.
https://www.corvetteforum.com/forums...post1570563689
I believe I've seen the 34 mentioned previously for just rough/erratic idle.
OP -
OP -
