Passenger seat recliner motor ?
So the recline function in the passenger seat of my 1988 C4 does not work. All the other functions do but that one.
Can anyone tell me where that motor is located and how big a deal it is to replace ? Any tricks for fixing or testing the old one ??
Can get a rebuilt seat track or just the transmission from $120 to $200.
OK so the recliner motor is part of the seat track ? Seems a shame to replace a track that everything else works on. I have seen recliner motors on Ebay for $45 up to $120
While I have read here that the seat track is not user serviceable, the recliner motor seems to just have a couple of bolts and a piston / actuator arm.
My advice was for the standard seat what do you have?
motor is under the seat cushion.. It is possible you have a bad switch so I would look into that too..
once you pull the lower cushion you should see the motor and gauge the difficulty..
there is a wire clip in the center of the front of the seat the hooks around the bottom shell, a little pressure/weight on the cushion and the wire clip should move back to free the cushion for removal
If the switch is OK.....and there is noise when you activate the switch, the problem would be in the seat transmission, not the track itself. You can get a rebuilt transmission.
OP - Do you actually have the FSM for this car yet? There's a good bit of misinformation in this post and it would certainly be in your best interest to check the FSM for operation for "your car"!!
The recline function is cable driven by a motor to a gear nut assembly. Lot's more to it other than just switch & motor!!
Motor is #29, cable #28 and the gearnut #23
Attachment 47985251
Attachment 47985251
Seat transmission has nothing to do with the recline function
