L98 Check Engine Light & Code 13
Cruising
Good morning my friends,
My C4 L98 is having an issue with the service engine light. I ran through a diagnosis with a paper clip, and found out it was sending the code 13 which is oxygen sensor circuit loop. I replaced the sensor yesterday but the service engine light still persists.
I have no issues with the performance of the car, other than that I can't start off the engine right after I turn it off( I have to wait around 10 to 20 minutes to get it started. There is no cranking sound when the engine doesn't start off but only a clicking sound).
My average miles are around 11 to 13 which are considerably low.
I have no idea what the issues are. Any opinions?
Thank you.
Thank you.
I would see if the wire to it is melted and disconnect the battery to reset.
