Alarm went off after putting in Csty/Clk fuse. Help?
Old 06-16-2016, 08:00 PM
skaterofsox
skaterofsox's Avatar
Default Alarm went off after putting in Csty/Clk fuse. Help?
I bought a 1985 C4 and the Csty/Clk fuse was missing. So I bought a fuse and installed it and it started making a weird noise by the rear drivers side. And the interior lights started to work and also the security alarm went off. I had to unplug the battery. Did these cars come with a keyless lock/unlock? Any suggestions what that odd sound is? hELP? It stopped after I unplugged the fuse but now the inside lights don't work.
Old 06-16-2016, 08:29 PM
antfarmer2
antfarmer2's Avatar
Hook it back up and try locking and unlocking with the key. And starting the car.
Old 06-16-2016, 10:05 PM
skaterofsox
Okay. So I got it to start. If I keep the fuse in the antenna motor won't go off. Any suggestions?
Old 06-16-2016, 10:12 PM
antfarmer2
antfarmer2's Avatar
If the antenna is up disconnect the relay. Then replace your antenna mast the ribbon is broke. if it is a vert the relay is on the drivers side by the back curve under the carpet targa under the back plastic by the latch left side hidden in the foam.
Old 06-16-2016, 10:31 PM
skaterofsox
The antenna won't come up. Should it come up when I start the car?
Old 06-16-2016, 10:58 PM
antfarmer2
antfarmer2's Avatar
If the radio was on and the ribbon on the mast was not broke. you might be able to pull it up with needle nose till you fix it.
Old 06-16-2016, 11:45 PM
WVZR-1
WVZR-1's Avatar
Received 2,262 Likes on 2,025 Posts
You suspect this fellow to have a 'vert? Really!!
Old 06-16-2016, 11:58 PM
antfarmer2
antfarmer2's Avatar
I do not know what he has so I gave him both. Don't you have something better to do than butt surf me? Either help or go away.
Old 06-17-2016, 12:45 AM
skaterofsox
thanks fellas. I'll check it out. It just makes this funny noise as if it is trying to go up.
Old 06-17-2016, 09:10 AM
antfarmer2
antfarmer2's Avatar
It is
To Alarm went off after putting in Csty/Clk fuse. Help?
Quick Reply: Alarm went off after putting in Csty/Clk fuse. Help?
