Leaking oil drain plug
Old 08-28-2016, 08:41 PM
1993C4LT1
1993C4LT1's Avatar
Default Leaking oil drain plug
Doing my oil change this week. Last oil change, I looked at the washer on the oil plug. It doesn't look damaged in any way. What do I do to stop the leaking?
Old 08-28-2016, 08:53 PM
dpc4vett
dpc4vett's Avatar
You can get some stuff at auto zone that you put on the threads and stops the leak. I use it on mine and it doesn't leak a drop any more.
Old 08-29-2016, 12:20 AM
BOOT77
BOOT77's Avatar
They make diff type washers for sealing. I've used the soft metal crush style and metal with rubber center, but herd bad things bout the plastic ones. Like the plastic ones coming loose or worse.
Old 08-29-2016, 08:37 AM
1993C4LT1
1993C4LT1's Avatar
Awesome, thanks guys
Old 09-26-2016, 01:22 PM
msaby
8th Gear
msaby's Avatar
When I worked in the garage a very long time ago... We would take a piece of cotton string and wrap it a few times around the drain plug before tighten it. I had the same problem with my 84 this weekend. The string sealed it up, no more drips.
The following 2 users liked this post by msaby:
1993C4LT1 (09-26-2016), VikingTrad3r (09-26-2016)
Old 09-27-2016, 01:11 AM
Cliff Harris
Cliff Harris's Avatar
My experience is that the nylon washers split and leak. I use a copper washer.
1993C4LT1 (09-27-2016)
To Leaking oil drain plug
Quick Reply: Leaking oil drain plug
