94 Interior Lights Flash
My 94 interior lights just recently started acting up, they flash on and off and the door locks do the same in sync as does the door ajar light. It only happens when the car is cold with the engine running with the window down or slightly open, it does this while parked or driving then after the interior warms up it stops. I know it is a mechanical issue but my girl friend thinks it is a paranormal one and refuses to ride with me so I need to get this resolved! Thanks for any ideas on where to start.
Sounds like an intermittent short with one of the door ajar lights or maybe even a bad adjustment. Pull the center plunger out the switches on both sides of the car and see if it helps.
Welcome to the forum!!!! On the lower side of the door edges you will see a plunger door switch. Gently pull the plunger all the way out and gently close the door to ajust.
Beat me Jim
Beat me Jim
