observations of engines, valves and stuff
I just thought I would share some observations that raise some interesting questions. After having my heads CNC'd and new valves installed I find myself with a good deal of leftover parts.
I brought a pair of valves up here to the office to use as decorations. I've been looking at them and have noticed something interesting that tends to make one ponder. For example, the intake valve has deposits around the back of the valve while the exhaust does not. I suppose this makes sense because the gasoline mixture is hitting the back of this valve while the exhaust flows the other direction over that valve.
So then look at the combustion chamber side of the valves. I notice that the intake valve has deposits on that side while the exhaust valve has virtually none. Can I assume that because the intake valve is closed after combustion that the exhaust valve just attracts less depostis because it is actually open at that time, allowing the exhaust gases and solids to exit the valve rather than settle on it?
I also have to wonder about the long term usage of swirl polished valves. Sure when they are brand new they might help out some, but after the deposits start to gather on them I can't see them being effective anymore.
I always run premium gasoline of a good quality, at least I feel like it's a good quality, but I have some deposits regardless. Now obviously I can't take my engine apart every week and see how my valves are doing as far as deposits. I've got 8 intake valves with similar deposits, I was thinking about buying 8 different types of fuel system cleaner and soaking the valves in the stuff, and see which ones do the best job of breaking the deposits loose. Would anybody else be interested in an experiment like this?
Former Vendor
Re: observations of engines, valves and stuff (Nathan Plemons)
I think what you are seeing is normal.
The deposits on the back of the intake could also be oil burned off residue from leaky valve seals.
I have a valve from the miller high life top fuel dragster. This valves live was probably only ~2 minutes of runtime max. It looks like a mushroom! I too had it in my office.
:cheers:
:cheers:
Re: observations of engines, valves and stuff (ski_dwn_it)
I figured it was normal enough. My motor has been extrememly healthy so far. I'm just trying to make sense out of what I'm seeing. The thing that seems so wierd to me is how two valves, which are in the same combustion chamber can have such different deposits on the combustion chamber side.
My stock valves looked like that as well. It takes a long while for the deposits to build up anything major though. When I pulled my heads after having them redone with around 2500 miles on them, they were a little discolored but they did not have any deposits on them whatsoever. I actually used a buffing wheel to clean off those old valves that had that crud on them (ended up not using them though, just playing around) and that stuff is harder than you may think.
Re: observations of engines, valves and stuff (Vette92)
The intake valves will have the deposits from the entering gasoline. The exhasut valve gets much hotter than the intake valve because it gets surrounded by the hot gasses leaving the combustion chamber. That is why exhaust valves almost look burnt and intake valves generally have a little glazing on them.
Cruise-In II Veteran
Consider what your intake looks like.
The incomming charge is low (relatively) temp with EGR components that sits momentarily on the back of the intake valve; the outgoing charge is much higher temp and moving much faster.
Do the deposits on the OEM valves look to be deeper than the "swirl" on the backs of the new valves?
One more question, what's up with the grooves for the locks? Why does the intake have two and the exhaust always have one?
Re: observations of engines, valves and stuff (65Z01)
Here is the URL of a picture of one of my new valves It's just enough out of focus that you can't really see the swirl pattern.
http://www.wku.edu/~nathan.plemons/heads/valves.jpg
My stock L98 intake and exhaust valves both have double grooves, the lower is for the O-ring upper oil seal and the upper is for the keeper retainer ring.
Upper oil seal? That's a new one on me. The LT1 has one valve seal that slides down over the valve and snaps into place around the valve guide. This is why I posted this thread, I figured it would turn into a nice knowledgebase.
What does the Y on the bottom of the intake valve mean? I would first think for the Y body car, but this valve is no different than an F-body valve, I'm pretty sure they have the Y on them as well.
Can you guys tell that my job is boring? I get to sit around and intensely study a pair of valves.
1 Post
Would that also explain why they are heavier and seem to have a thicker base?
1 Post
Re: observations of engines, valves and stuff (sinistervette)
It's just me again! I forgot one other thing about the thickness of the exhaust valve. The egde thickness around the head of valve is refered to as the margin. If the margin is to thin on an exhaust valve, it will burn out quicker. Kind of like using a torch and holding it by a piece of 16ga. sheet metal, and then by a piece of 1/8". The 16ga. will burn out almost immediately, and the 1/8" will withstand quite a bit more heat! Another lesson learned the hard way! :D DON'T LET ANYBODY CONVINCE YOU TO BACK CUT THE EXHAUST VALVE FACE TO INCREASE FLOW! :lol: :lol: I did it to a pair of heads I was experimenting with, and lets just say that a flatbed bill from "BFE" Kentucky to Holland Michigan cost $320+! :eek: :cuss :cry
1 Post
Re: (Nathan Plemons)
They have a Y on them? I don't remember seeing that on any of mine.
Maybe L98's don't. But mine sure do.
